barebones wiring
  • barebones wiring
    Lets start with the fact I pulled all my wiring out of the buggy and don't remember how I had it wired before plus I'm a little burnt out and thinking about the wiring is making my thoughts blur.
    Rig is carbed no harness's just a switch panel with fuse block and a few bus bars for hots and grounds.
    I have a new mini starter that replaced my old style starter. Got a new starter solinoid for the bronco too.
    Starting with grounds......
    1 line from bus bar for switch panel and fan solinoid to battery negative terminal
    2 line from engine block to either bus bar or battery negative terminal
    3 line from starter to starter solinoid
    4 taurus fan ground to engine block
    HotS....
    1 bus bar for switch panel to positive battery terminal
    2 starter solinoid to positive terminal on battery
    3 line from ignition switch to s on starter solinoid
    4 line from dizzy to i on starter solinoid
    5 line from fan solinoid to taurus high speed positive wire
    I think thats all correct
    where does the start switch/button go on starter solinoid?
    How does the new mini starter wire in since its different?
    Re: barebones wiring
    Check these out and see if it looks right for your setup: From your description, you want a triggered output off the relay and a constant hot off the battery.
    http://www.cjponyparts.com/Tech-Mini-Starter/a/155/
    http://www.wildhorses4x4.com/downloa...2010-20-08.pdf
      HotS....
      There is no wire from distributor to i post. The wire goes from i post to COIL battery +, downstream of the ignition resistor circuit.
        Correct, and dizzy to coil
