Ford 9 rearend, professionally built, low miles
  • Ford 9 rearend, professionally built, low miles
    Ford 9 inch rearend, professionaly rebuilt with all new bearings and seals, new 4.11 ring and pinion, 28 spline axles, new Detroit Locker, and the big 11" drum brakes (noted as a much better option over the 10.5's for cooling), The housing is a big bearing rearend and is the banjo style. It is currently in a 73 Ford Early Bronco. Fully rebuilt less than 600 miles ago. Can come with extra axles too. This is not a full size axle it is narrower. 5 0n 5.5 bolt pattern.
    950.00
    Sold
