That's cool! Thanks for sharing. If I go to a Pick and Pull, it would be an all day excursion (nothing close to me) so knowing what's there would really help.
As big as Ecology is in Socal and AZ I'd think they'd have something like this. Used to be you could call and they'd run a inventory check for you but they don't even do that anymore. An online tracker is the catz AZZ!
They've had it for awhile. Really saves time. Helps me decide which of the 3 closest ones I go to first. Pretty accurate too. Every car I've looked for has been exactly where they said it was unless they had just pulled it from inventory to be crushed that day.
