Just put my driveline in for my D44 upgrade. (had it shortened) I have a D44 with a Detriot(i think) from the PO. My question is In 2WD drives and steers just fine. In 4WD it will not turn with out a fight!!(on the STREET) Power steering pump squeeks and spits out fluid. Steering just wants to retun to strait.. I realize that this is on the street but shouldnt it have some give?? When i get into the MUD There is no resistance. Then i ulocked the hubs. Kept it in 4 LOW and same thing DIDNT want to turn? Is there something else going on???
Ohh its a bitch to get out of 4 low. T shift (two hands)
The locker looks like a Factory limited slip BUT there is no window to get to the spider gears. the whole carrier is a solid metal casing I could not see if it was hallow or if it had gears in it.. Not even any cross locking pins.. If this is solid then this would act like a full spool for the front.. It dosent look like a standard spool by any means but acts like one,, what is this thing??
Any ideas??
Thanks
Aaron
Any ideas??
Thanks
Aaron
