Hello! New to the forum and Broncos in general so I'm looking for some advice.
Started a project 86 BII last year with my dad in Colorado. Put in tons of work, lift, suspension, new steering everything, regeared, replaced cylinder heads. 8.8 swap etc.
Only issue is I live in the bay (SF) and am now without tools and space to keep working on the project on my own, and I've had some issues pop up.
So now I'm looking to invest some money and take it to a shop to fix a few things. I understand this is gonna be a bit of weighty post, but any thoughts or recommendations on any of the below would be greatly appreciated!
1) First problem is wiring. Fuse box had a minor fuse-explosion so it's about 1/4 fried. As far as I can tell right now it only affects the turn signals, and occasionally the radio, I can live without addressing it just yet but I'd like to just get it replaced and taken care of. Anyone have good recommendations for a shop to take care of the wiring? Would it be reasonable to assume if I can find a replacement box I could handle the wiring myself with careful labelling?
2) Bigger problem is the clutch is going out. It still shifts but started hearing some gnarly noises getting into first gear. I know pretty little about clutches tbh, but I've read you can either pull the engine or the transmission to take care of it. Anyone have any experience with replacing an old ranger/bii clutch issues or know of a good mechanic to take a look?
3) And the biggest issue is just last week started having an idle where it will run normal and drop low to just barely running. Drove it a mile and the engine was just totally gutless at times too. I'm assuming a vacuum leak at minimum, but would love to find someone/a shop to take a look at it and let me know if it's anything worse.
There's a few other smaller things I'm thinking about such as an electric fan, and the slight issue of the e-brake not exactly working but... I'll deal with those later.
Thanks in advance! Attached an obligatory photo as a peace offering.
