I've been looking around for a set of 17" wheels for my Bronco, for some mythical day when all of my parts arrive and I can drive it again.
The choices for a 17" wheel with a 3.5" backspace are pretty few and far between.
Wild Horses sells the US Mags "Indy" in 17" with 3.5" backspacing, in polished aluminum. It's not a bad looking wheel and is sort of "classic" on the EB. If that wheel was offered in a black powder coat I'd be more interested in it. My Bronco is orange with almost no shiny stuff on it - black wheels, bumpers, cage, and minimal chrome (emblems etc). I am hoping to stay with the black accessory motif.
Tribal knowledge says that you need 3.5" wheel backspacing on an EB. However searching on classicbroncos there are a lot of people running 17" wheels from Method and Fuel with a 4.5" backspacing, and they say they fit without issue.
My only known interference with my current 15" wheels (with 3.625" backspacing) is on my silly looking Rancho remote reservoir shocks in the front. I can relocate the external reservoirs and very likely eliminate that rub problem - and as I run "CAGE" radius arms (similar to what is currently offered by James Duff) I have no issues with tires getting close to the radius arms. I run stock width EB axles.
Why do I want 17" wheels? Mainly because I like the appearance, and also because the tire choices for 37" tires are more plentiful should I decide to stay with 37" tires. Even if I go to a 35" tire, I feel that a little less sidewall would help my on-road handling. Given that I put most of my miles on, on the pavement, everyday handling ranks high with me. I do plan to wheel, but I also will be driving in normal everyday situations, as well as driving to/from off road trips.
Long story short - if any of you have experience with running 4.5" backspacing on similarly equipped rigs, please share with me any clearance/rubbing issues that you have experienced and how you have overcome them.
Alternatively, if you have located 17" wheels with 3.5" backspacing, perhaps your searches have been more fruitful than mine have been, please share links to any such wheels that you may have found.
I am not totally opposed to running a true bead lock wheel, however for a variety of reasons I have a bias towards normal non-bead locked wheels. For one, to date I have never popped a bead on my existing wheels, running pressures down around 15psi. I haven't really had reason to drop the pressure any lower. And for another - I don't know that I necessarily want the extra maintenance of re-torquing bead bolts, and running a wheel that's questionably legal on our highways. I don't really want to get into a debate about the legal aspect here, I am more interested in what I have already asked above.
Thanks in advance.
Thanks in advance.
