Shop to rebuild steering gear box?
  • Shop to rebuild steering gear box?
    Does anyone know a good shop that can rebuild a 2007 F350 steering gear box? I don't mean just put new seals in it, something it broken inside. The pitman arm just flops back and forth. Probably has a broken sector shaft.
    Re: Shop to rebuild steering gear box?
    It would probably be easier to use that as a core and get a reman.
      I bought a reman box for my truck. as I recall it was a couple hundred bucks or so, with a good warranty. it's been on my truck for probably at least 100k miles. Came from a local chain, Monument.
        Red Head Steering Gear. I believe they are in Portland. They are the best. They send you a reman. You swap them out. You send your old one. They credit you a core charge.
          Second on the Red Head Boxes. They rework the entire box and components to better than factory specs.
          76, DuPont midori sour green, explorer 5.0, Mild built C4, D20, 1 ton steering, 44 w/soft locker 4:11, 9" w/locker, 4.5" lift, 1" NHL Bodylift, Duff front long arm's,4.5 WH front and rear, 35 toyo's, FloFit seats and other dodad's.
            Thanks, I will see if I can find their number and give them a call.
              Here's their website:
              http://www.redheadsteeringgears.com
              They are in Washington.
