Does the twin stick kit for the Dana 20 use a lock-out plate like the stock set-up?
If the stock 'T' shifter uses a detent to hold the transfer case in a gear range, how does it work with the twin stick?
My D20 keeps slipping into neutral at speed for no apparent reason. I cannot duplicate the conditions to make it slip out, so I can't find a fix for it.
The lock-out plate is crisp, and the detent is not worn.
I am wondering if the twin-stick kit could solve the problem because when it slips into N from 2H, I must stop to get it back in, even on the freeway. It is becoming a potentially dangerous problem since I live on mountain roads.
Suggestions?
Suggestions?
