I am continuing to experience some major steering problems. The bronco is very twitchy...darting left and right with very little input from the wheel. Virtually all the steering is new. The vehicle actually drove very nice prior to a very minor accident where I bent the track bar drop bracket. I ended up putting on a axel riser bracket and replaced the frame bracket with a stock like bracket. The track bar and drag link are still parallel, but are now separated by about 3-4 inches vertically. The frame side pivots for the track bar and drag link were pretty close together when I had the drop track bar bracket, and are now spaced apart. I would like to try to get the frame side pivots close to each other again, and would like to drop the track bar on the frame and/or raise my pitman arm.
Might anyone have a pitman arm with little to no drop and a track bar bracket I could try to see if this works????
Alternately I could go to knuckle over arms on my Dana 60 king pin if anyone has arms I could try????
Appreciate your help and ideas.
