My Bronco is at Arabia's overkill getting some damage from a drivers side front accident I was involved in repaired. It appeared that the only structural damage was a bent track bar drop bracket,. but after replacing the track bar and bracket, as well as the 4X4X2 box....the truck is literally dangerous to drive on the freeway. It wanders left and right severely.
Toe is 1/8" toe in, Caster is 3.5 degrees. camber is .1 degree. Duff monster long arms, with rigid mount to a dana 60 in the front. Axels are equal length within 1/8", frame has been checked and is good.
Steering box/frame is plated, all new tie rod ends, Dana 60 with king pins might be the problem?? Might be my rag joint....
Any ideas on what to check or places that could help Arabias figure this out. Thus far insurance has been footing the bill....hopefully they will continue.
Appreciate your thoughts. Dave
