I did a little experimenting with my smoker today. There are those who say that Tri Tip is not a "smoking meat", but its what I had, and my results were very good.
I started with a large tri-tip, coated it lightly with Pappys, followed by some crushed raw garlic, followed by some chili powder. I set my smoker to 250-300 degrees with lump charcoal and a log of seasoned almond wood. The tri-tip smoked for about two hours and came off when it reached about 160 degrees. While it didn't taste quite like the typical Santa Maria style tri-tip, it was damn good. The juices were flowing out of it when I poked it with the thermometer.
I want to try this again with a different cut of meat sometime soon.
FYI, my smoker is actually a gas grill that doubles as a smoker by using a side fire box. I don't turn the gas burners on while smoking unless I need more heat, and then its the farthest away burner on very low. I've been able to regulate the temp with the side fire box much better than when I used to use a drum smoker.
