The best BBQ Baked beans...
  • The best BBQ Baked beans...
    1 pound smoked brisket or bacon cut into 1/4-inch
    slivers
    1 can (15 ounces/can) black beans
    1 can (15 ounces/can) dark red kidney beans
    3 cans (each can 15 ounces) baked beans or pork and
    beans
    1 large sweet onion, finely chopped
    1 red bell pepper, cored, seeded and finely chopped
    1 poblano pepper or green bell pepper, seeded and
    finely chopped
    4 cloves garlic, minced
    3 to 6 jalapeño peppers, seeded and diced (for hotter
    beans, leave the seeds in)
    2 cups sweet red barbecue sauce (your favorite
    commercial brand)
    1 1/2 cups firmly packed ligh brown sugar, or more to
    taste
    1/2 cup Dijon mustard, or more to taste
    2 teaspoons liquid smoke (optional; see Note)
    coarse salt (kosher or sea) and freshly ground black
    pepper
    Directions
    You’ll also need: 1 large (turkey-size) or 2 medium-size aluminum foil pans; 2 cups wood chips or chunks (preferablypecan or hickory) soaked for 1 hour in hot water to cover, then drained.
    If using bacon instead of brisket, place it in a large skillet over medium heat and fry until crisp and golden brown, about 5 minutes. Pour off all the bacon fat, saving a few tablespoons for the beans, if desired.
    Empty the cans of black and kidney beans into a colander and drain. Rinse the beans under cold running water anddrain again. Place all the beans (including the baked beans or pork and beans) in a large nonreactive mixing bowl and add the onion, bell and poblano peppers, garlic, and jalapenos and stir to mix.
    Add the barbecue sauce, brown sugar, mustard, liquid smoke, if using, and brisket or fried bacon and stir to mix. Taste for seasoning, adding more brown sugar and/or mustard as necessary, and salt and black pepper to taste; the beans should be very flavorful.
    Transfer the bean mixture to the aluminum foil pan or pans. (If you used bacon, you can drizzle a few tablespoons of bacon fat over the beans for extra flavor.)
    Set up the grill for indirect grilling and preheat to medium-low. If using a gas grill, place all of the wood chips or chunks in the smoker box or in a smoker pouch and run the grill on high until you see smoke, then reduce the heat to medium-low. If using a charcoal grill, preheat it to medium-low, then toss all of the wood chips or chunks on the coals.
    When ready to cook, place the pan of beans in the center of the hot grate, away from the heat, and cover the grill.
    Cook the beans until they are thick and richly flavored, about 1 hour. If the beans start to dry out, cover them loosely with aluminum foil.
    Remove the beans from the grill and let them rest for 15 minutes, then serve.
    Note: If you cook the beans in a gas grill, you probably won’t be able to generate enough smoke for a strong wood
    flavor. Add the liquid smoke in this case.
