Go Back   Northern California Bronco Club > NorCal Bronco Tech
Register FAQDonate Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 03-16-2007, 03:07 PM
highlander's Avatar
highlander highlander is offline
Contributor
highlander will become famous soon enoughhighlander will become famous soon enough
Default Bronco 4-link pics and ideas
Well in trying to decide the best way to link the rear of the bronco I have found a few pics, I thought I would share them with all of you. If any one else has some more to add I would like to see them. Any comments good or bad about these are welcome.
ID:	4007  Click image for larger version
ID:	4009  Click image for larger version
ID:	4011  Click image for larger version
ID:	4013  Click image for larger version
  #2
Old 03-16-2007, 03:13 PM
highlander's Avatar
Contributor
Default
This one isn't a Bronco but is a liitle diffrent way of doing the upper links that uses leaf spring bushings instead of JJ or rod ends making it a little less expensive.
ID:	4015  Click image for larger version
ID:	4016  Click image for larger version
ID:	4017  Click image for larger version
  #3
Old 03-16-2007, 03:25 PM
TRAILBOUND's Avatar
TRAILBOUND TRAILBOUND is offline
TRAILBOUND is on a distinguished road
Default
I like the design on the second one, you cant beat the simplicity of it. I think having your lower arms as far down as possible without interfering with ground clearance is the ticket.
As for the first one and the duff proto-type, i would think that the huge bracket they weld on to the top of the rear housing would limit the 4 link in upward travel. but then i guess thats what BL are for.
The last one mounted the lowers where i think they would work best, i don't know what to say about the beefy single upper and single center pivot.
this one is sweet
__________________
72' 302 NP435/D20 5.5sl 2 bl FW44/9 HB on the way, 3 link front on the way
  #4
Old 03-16-2007, 07:37 PM
720Racer's Avatar
720Racer 720Racer is offline
Go on...........GET IT!!!
720Racer will become famous soon enough
Default
Highlander,
When I loged on today, I was reading your thread in projects, and was thinking that I should start a thread (like this) for a place for pic's/ideas. Glad I'm not the only one trying to learn more about link suspensions.
Galen
__________________
1966---302, 3 spd, 4.11's, SB9, D30, 3 1/2" lift, 33" Bridgestone Mud Duelers, lots of rust
1969---A frame, a welder, and some crazy thoughts...........stay tuned
Barret Lake......2008
  #5
Old 03-16-2007, 07:53 PM
Daddy4zack's Avatar
Daddy4zack Daddy4zack is online now
Moderator/Contributor
Daddy4zack is on a distinguished road
Default
Those 4 links look pretty easy.. Don't get me wrong.. I know the angles and geometry is the hard part.. But Clean looking not a lot of clutter.. All the premade brackets now available helps.. I tried to order Jonny Joints today and they are Backorderd..
Aaron
__________________
70 Miles to the Rubicon!
  #6
Old 03-16-2007, 08:17 PM
720Racer's Avatar
Default
Maybe we could start with some definitions?
I keep seeing these words, but don't totally understand what they are refering to.
anti-sqaut
roll center
roll axis
instant center
__________________
  #7
Old 03-17-2007, 07:32 AM
Daddy4zack's Avatar
Default
I was getting my Jonny joints from Poly performance.. They said they are back ordered.. So I checked Summit and the same.. Checked Currie..and they are the back order source.. So I will wait a couple of weeks..
Aaron
__________________
  #8
Old 03-17-2007, 08:23 AM
crawlin68's Avatar
crawlin68 crawlin68 is offline
crawlin68 has a spectacular aura aboutcrawlin68 has a spectacular aura about
Default
HERE is a link to a guys profile on the Pirate board who has an excellent 4 link calculator. In his profile, click on the "4-link calculator" link and will open the file.
  #9
Old 03-17-2007, 08:36 AM
highlander's Avatar
Contributor
Default
That looks like the same one I posted earlier!
  #10
Old 03-17-2007, 08:38 AM
highlander's Avatar
Contributor
Default
I take that back, it is the same but yours is a newer revision, nice!
  #11
Old 03-17-2007, 10:09 AM
crawlin68's Avatar
Default
Oh, I didn't see were you had posted it. Sorry for the dupe. Although mine is newer. LOL!
  #12
Old 03-18-2007, 10:57 AM
NOTPRETTY's Avatar
NOTPRETTY NOTPRETTY is offline
Must....wheeel....
NOTPRETTY is on a distinguished road
Default
I curious about the 14 bolt pic... Where is that from?
__________________
See my club's forum/site: http://www.calcreepers.com
  #13
Old 03-29-2007, 08:40 AM
SonicDonkey's Avatar
SonicDonkey SonicDonkey is offline
EB User / Contributor
SonicDonkey is on a distinguished road
Default
If you cannot get the JJ parts from Currie why not use the Super-Flex parts from Rubicon Express.
http://www.rubiconexpress.com/Builde...=70B32A1167112
  #14
Old 04-29-2007, 06:17 PM
maui matt maui matt is offline
maui matt is on a distinguished road
Default 4and 3 link
Here are a couple pics of my 4 and 3 link in my rig and pretty much the same set up thats going on my 66
ID:	4634  Click image for larger version
ID:	4635  Click image for larger version
ID:	4636  Click image for larger version
ID:	4637  Click image for larger version
  #15
Old 04-29-2007, 07:31 PM
720Racer's Avatar
Default
OK,
I guess I'll just go haul all my sh*t down to the dump after seeing that!!!
Very nice.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
