Early Bronco Trail use tube doors for sale. The doors are made from 1 3/4" x .095" tubing. My standard design uses the door post part of the original hinge along with the stock hing pin. The latch is a simple turn lever to catch the stock door post striker. A rubber cushion is supplied to eliminate rattling on the striker. The doors come in bare metal to be finished by the customer.
The cost of the doors is $275 plus shipping. I usually have a set or two built and in stock. If not I will make sets as requested. I will not take any money until the doors are ready to be shipped. I will do my best to get them made as quick as I can for you, but this is not my main job so it may take a week or two to get them made if I dont have any in stock at the time.
I also make them to fit the Drake lift off hinges. I can supply them without hinge mounts if you would want to do your own. PM me if you have any special requests and I will see if I can do it for you.
Feel free to contact me if you have any questions or need any additional info.
Thanks,
Rob Carlson - 608-343-0713
rcmbronc@centurytel.net
Thanks,
