So I was playing in the snow, and there was a loud thud, like I had hit a rock under the snow, not such a big deal since I recently obliterated my steering stabilizer there isn't much to damage under there. Then I hit another "rock" in a place I knew there weren't any rocks, after getting out to look I found that one of my radius arms had broken in two!!! I am running a set of Lars Bars, they use 2" DOM, 1/4 wall and are fish-mouthed to fit into the existing radius arm fronts. A close inspection showed that the DOM appeared to fail right behind the weld, it appears they failed fairly recently because the crack has very little rust on any parts. Based on appearance it appears to be a fatigue failure because the steel isn't necked down at all. It looks like the failed starting at the top and worked its way down. The failure either began because of proximity to the weld or because of a stress concentration caused by the end of the remaining portion of the original radius arms. I fixed it by inserting a 20" piece of 1.5" DOM 1/4 wall inside the existing DOM (easier said then done) and welding it back together, but of all the parts I don't ever want to break, the radius arms are right up there with steering linkage.
I am running 4 degree poly C bushings that look like they are an old Duff set, they are VERY stiff, maybe that is part of the problem? Has anyone else had trouble with this?
